Y61 Manual Transmission! Are tb48 same as tb42?
8.2K views 2 replies 3 participants last post by  pedrogomezhenriquez
Hi there,
Trying to find a tb48 manual transmission and after looking for part numbers (FS5R50B) it seems as though the same transmission is shared between other models such as the tb42, tb45, zd30 and td42.
Would it be safe to assume that the only difference externally is the bellhousing ?
From what limited info I have the only internal differences are the ratios of the box.
Would using a tb42 box with a tb48 bellhousing make it the same as a factory tb48 transmission or are there other internal differences between the transmission that set them apart?
Thanks
