ATF oil in 4.2TD manual transmission
1 reading
12K views 10 replies 9 participants last post by  GU 4.5
Hi all I have a GU 99 coil cab ute 4.2TD. I was told by a friend who was in the comp scene to run ATF oil in gearbox to get better gear changes. He was saying almost like a quick shift. Has anyone else tried this.
#2 ·
I use redline synthetic MT90 pushing close to 700Nm through it and the gearbox temp rarely goes above 100 degrees.
costs about $300 for box and transfer. I'd prefer to pay that if it saves me changing out that beast of a transmission even once.
I think ATF will be too light.
#7 ·
I am not an oil expert but what i do know is ATF is designed as a hyd oil which will handle high temp but i am not sure it can handle the extreme pressure point loads that a high torque engine can exert on to the gear teeth. The oil has to protect the gear teeth contact point other wise the hard casing on the teeth will wear off, then you get noise and wine etc etc, This is what gear oil is designed for. Sure ATF will make gear changes easy but at the expence of the gear teeth over time i would think you would destroy a gear box eventually.
#11 ·
Hi guys i,m usualy a penrite guy all the way but i tried castrol vmx-m & it has improved the shifting in my gearbox of my 2000 gu 5 speed & i use royal purple full synthetic atf oil in the transfer have had no dramas with hard shifting in the gearbox & i am very impressed with the engaging & disengaging of the transfer to.
