There always seems to be a question of where and what EGT temps are acceptable with GU ZD30 motors. If any of you are interested in the result, Ill correlate it.
Where is your EGT sender mounted, what brand gauge (major brands will be separated minor brands will be "others"). Pre turbo give me the distance from the closest turbo flange and the temp range you experience, cruising, towing and city, if post turbo do the same, also add whether DI or CRD. Can anyone suggest further categories.
