Hi all,
I have been for some time now chasing this stuttering from the engine whilst under load, Eg. accelerating above qaurter throttle and only in first and second gear.
I have been to many mechanics all of which said a fuel related issue. So i have changed the injectors, i have checked the IP for a gauze filter (didnt have one, checked by two people). I have changed the fuel filter twice, and i have recently added a Carter P4600HP fuel pump to the system as the last diagnosis was that the lifter pump inside the IP had worn and was not delivering enough fuel under load.
After installing the carter pump before the primer pump and fuel filter housing i bled the fuel system and the injectors, and after that it was actually idling better than it ever did. But a short drive later and the stuttering is still there. Its not as bad as it used to be but its still there.
I have been asked is if it blows any coloured smoke, no it does not. Doesn't even blow black smoke during the stuttering as it looses power whilst it happens.
Another suggestion i had was the fuel tank. I have not checked the fuel tank yet for any crap in the bottom, i can do so but i would have to either drop the tank or completely remove my drawers to do it. But when changing the fuel filter i have not noticed massive deposits of crap, or at least no more than normal.
I am completely baffled at this. I cannot resolve it and its costing me an arm and a leg to do so. I really just want to find the problem. Any ideas?
