My td keeps overheating when on a hill underload have tried everything just got a new thermostat to put in see how it goes but what else could it be
Here are 149 pages of info on overheating 4.2.My td keeps overheating when on a bill underload have tried everything just got a new thermostat to put in see how it goes but what else could it be
With respect the all the contributors, myself included, there are no answers in there. Lots of theories and experimentation, but no answers.Here are 149 pages of info on overheating 4.2.
Engine running hot TD42???
spent hundreds if not thousands trying to stop it running hot ??? well i have the answer for you and it is fairly cheap , no need for multi pass alloy radiators or anything like that , although i do recommend that all cooling system componants be in good running order this fix is for most if...www.patrol4x4.com
Cooling system efficiency is not a single fix. It involves many components working correctly. As stated above, air flow is the most important however i.e if your radiator is blocked then air flow will do very little...and so on. Quality components is another big factor. High flow pumps, 3 core aluminum radiators etc won't do jack on their own if they're not working in unison. And, all this assuming that there are no other mechanical issues head gasket etc.My td keeps overheating when on a bill underload have tried everything just got a new thermostat to put in see how it goes but what else could it be
