I am the proud owner of a Dec99 build TD42T Patrol.
Since having a new radiator fitted March 2015 followed by Thematic Fan hub, Thermostat and radiator cap my temperature gauge indicates that the temperature is rising to top of scale intermittently. This can occur in cold temperatures 10 -20 deg C. and while traveling on level grounds. I must add that it only is occurring while towing my caravan ( 18 ft Roadstar single axle), and at the most unexpected times i.e. long flat roads. I generally stay in the speed range 85 - 95 kph (2000 - 2200 RPM).
I have recently completed a short trip where max temp outside did not exceed 20'C, 550 km overall distance. The stretch of long uphill haul over approx 2 km (110km into journey) was where I expected the problem to occur but it did not. However after 300 km the temperature fluctuations occurred continually. Without altering speed on the flat ground the temp would just as quickly drop as it rose.
This does not happen when running with no towing load behind, In the middle of this trip I had two trips over 115 km in ambient temps of 23 -24'C that we completed at speeds of 110 km average.
Am currently in the process of renewing all electrical connections between van and vehicle to eliminate earthing etc. as a potential problem.
I will be fitting a genuine Nissan thermostat in the next week as I am sure the service agent has fitted an aftermarket brand.
Would greatly appreciate thoughts and suggestions for remedies.
As an afterthought the service shop has suggested they want to scan the vehicles engine management's system board for fault codes. I was under the impression that this vintage of the TD42T was free of such "refinements".
Can anyone help me with the answer here
