Zd30 fuel primer
3.2K views 3 replies 2 participants last post by  geeyoutoo
My fuel primer is not working. Iv pump it for a minute and it not putting fuel though dose anyone know how I can bypass it. I have a zd30
#2 ·
Don't bypass, it serves a purpose. Instead look for loose hose clamps, cracked hoses, etc between fuel tank and fuel pump. Yes the primers do fail but not that often, had my DI 21 years and still original primer.
#4 ·
Have you recently changed the fuel filter? There is an '0' ring on the thread that holds the filter and it is easily lost and cause air ingestion.
Do a quick test, fill a bottle with diesel, take the inlet hose off the fuel filter inlet, connect a short section of hose to the inlet and into the bottle and try prime again.
