I didn't think to ask the dealer this one but how does the subtank work on my new 06 3L? Does it have a pump to pump diesel to main tank or do i switch to it via a selector in the car? I don't have the truck yet hence my question lol
Thanks mate. Keeps me busy. :anger:jimsaq said:great site grungle
I'd say it's best to have the engine running, purely so the battery wont get drained.Is it better to have the engine running or on accessories when pumping fuel from the Sub into the Main tank?
Thanks
Bro, this is golden.1. The sub will not pump (whether manually selected or on startup) when the main tank is full. This is so you do not pump fuel out the expansion/overflow outlets onto the ground.
2. The sub will pump approx 1 litre on startup when the main tank level is below approximately 7/8's full (as previously said). It will empty pretty quickly if started frequently.
3. The sub will not pump when down to approximately 2-5 litres left in tank.
4. You can check to see if sub is pumping on startup if you remove main tank filler and start engine. The sub empties into the main filler neck approximately 4-5" down so you can see it.
5. The sub tank is controlled by an ECU and looks at several sensors. The ECU is prone to lock up with certain types of turbo timers due to losing one of the voltage lines.
6. If you get a sub tank light illumination, disconnect the battery first for a few minutes (negative only). This should fix over 90% of the problems. There are earth issues with the sub pump as the chassis is not earthed to the body. Also turbo timers cause the sub tank light to illuminate.
7. You had better hope that you do not have a sub pump failure as they are $800 a pop. If you do, get a bocsh pump and wire it in bypassing the ECU, or
8. Pi$$ the whole system off and put in a Toyota 75/79 series fuel changeover system. That way you can suck fuel from either the main or sub direct to the engine. Very handy if you get a tank of bad fuel. This is something I will be doing if my 3rd sub tank pump fails.
Regards
David
Guys dumb question, as I have a 2015 patrol ute is the sub tank switch spring loaded or should it lock in when you push it in ad mine doesn't and always display sub tank no matter what I do with the switch.Thanks for the heads up, I filled up the sub and transferred it to the main tank today.. glad the thing works.![]()
It should lock in, but, it won't transfer until a certain level is reached in the main tank. Try disconnecting the battery for 15min and see if the system resets.Guys dumb question, as I have a 2015 patrol ute is the sub tank switch spring loaded or should it lock in when you push it in ad mine doesn't and always display sub tank no matter what I do with the switch.
Hey mate, I am having some issues with the sub tank on a 2004 GU Ute. The light on the switch was turning on but not pumping fuel. I checked the voltage at the pump . Was around 5-6V The fuse was ok. When I put the plug back in the light now doesn’t work.Test /fault mode did not work. Tried that several times. Any ideas would be much appreciated. Cheers PaulJust a word of advice.....always keep some fuel (preferrably full, or close to) in the sub tank so that the pump does not get stuffed trying to pump non-existent fuel across each time you start the vehicle. The transfer pump is apparently VERY expensive as well as being a bit sensitive.
Hey there, which pump is the correct one to get? I will have another look at why it’s not working . I am thinking replacement of the pump is needed1. The sub will not pump (whether manually selected or on startup) when the main tank is full. This is so you do not pump fuel out the expansion/overflow outlets onto the ground.
Regards
David
Also anytime you start the vehicle, I believe a tiny amount of fuel is sent from the sub to the main.
I can confirm this behavior is happening on my 2018 GCC spec Y61. Firstly, I thought this is an issue. But it makes perfect sense from the safety point of view: dashboard computer must be able to diagnose and fire up a warning light “aux pump oopsie” when you start your journey. Finding out that oopsie in the middle of desert isn’t that nice.everytime you start the car the tranfer pump automatically transfers fuel into the main tank for 10 seconds....
The pump runs for around 5 seconds on start up, the more short runs you do the more those 5 seconds mount up. If you don't top up the sub at each fill you eco numbers will not be accurate.I can confirm this behavior is happening on my 2018 GCC spec Y61. Firstly, I thought this is an issue. But it makes perfect sense from the safety point of view: dashboard computer must be able to diagnose and fire up a warning light “aux pump oopsie” when you start your journey. Finding out that oopsie in the middle of desert isn’t that nice.
Photos from June 9 and June 19 attached.
Well, it seems it messes my fuel consumption measurements a little bit, probably adding an error of nearly 1 liter per 100 km.
