Hi Guy's. A conversation with Maxchickens over a year ago made me look at ways to control the VNT, his CRD VNT is controlled via a Chip, I didn't want to go that way so looked at my options.
I wrote my findings up in great detail in my build thread early last year with pages of data from my ECUTalk log over many hundreds of K. What I'm interested in is feedback from anyone else who has tried it since getting a remap. Remember mine is a manual so an auto will react differently but I will assume similarly in certain conditions. It would be great if someone with an auto could contribute.
Like many others in the old days I found the std vacuum solenoid was not reliable in controlling boost and would often cause extremely high EGT when it fell to ridiculously low boost at what appeared to be (then) erratic times, so we went for the classic NADS boost control system bypassing the Vac Sol, my EGR was actually blocked from day one of becoming aware of this forum. In the remap it is turned off as well but there is still some trickery going on in the ECU.
I'll give a brief summary of what was found:
1. After initial remap I decided to try reconnecting the Vac Sol to see what happened, all good driving around locally, no issues (I'll add that when I first dragged it out of the shed and reconnected it the damn thing chattered like crazy so I filled it with WD40 and let it sit, then blew it out and sprayed it with MAF cleaner, then all was good).
2. The next step was obviously a longer high speed trip and this is where it got interesting, I started to notice a short blip in the boost that recovered very quickly, it took quite a while and studying pages of ECUTalk data I had gathered, but a pattern finally emerged. Over 100Kph in 5th (and only 5th) would cause something in the ECU to seek backup info for the EGR, this caused the VNT to react and drop the boost to just over 5psi, when the ECU didn't get this feedback the boost returned immediately to normal, it would go through this cycle a few times and then seemed to forget about it for a while, EGT would rise slowly while this was happening but no more than 350c from memory and then drop back to low/mid 200's. I could drive around at 100k and under and it would not happen, as said I have pages of data where I could see the reaction of VNT%.
3. I found boost control (not max, that's later) to be much finer and in fact a little lower on average as the VNT arm danced to the tune of the ECU requirements.
4. Later I tried making the Vac Sol the complete manager of boost including max but that was a dismal failure, I kept hitting limp for 095, so the Dawes was reconnected.
5. Later I drove for months with a vacuum tank between pump and Vac Sol, this hid the effect because by the time the tank capacity had been used the ECU stopped looking for the 'feedback' and full vacuum restored, however because the vac servo is a constant it raised the average boost reading by around 1psi so the VNT was not dancing as well, have since disconnected the servo tank and vac is connected straight to the Vac Sol once more and all good.
Would be interested in any feedback from others who have tried it.
