Just wanted to put a post up to help some people that are struggling with the lower output alternators that are on offer in AUS.
Up until recent times, I had been running a 150amp alternator that was struggling to supply my needs under full load. With the modifications that I am doing, the output was not going to cover it. After searching for quite some time, I came across a place in America that sells, direct bolt in replacements for the TD 4.2. Turns out they have a reseller in Vic.
Took around 1 month to get here from order, as they have to make them. When it turned up, didn't fit. Turns out the alternator is a direct bolt on for a GQ with the twin pulley on front. They were not aware of the variants in models. The upper bolt hole for the GU was 10mm to low, and the lower bracket was 10mm to high. I took this to my local aluminum fabricator who I had weld and re-drill the casing on the upper, then on the lower remade the back bracket (Which is steel). Unit now bolts straight in and I have a 270amp v belt alternator.
What I also did was replace the pulley with an item I located from SA that I had on my previous alternator, which makes the ratio around 2.75:1 (Ideal pulley to crank ratio is 3:1). Now with the truck at idle, I get roughly 100+amps feeding into my battery. Image below shows truck at 1500rpm idle, around 180amps. Note, this is going into the battery, so add roughly 30 amps of draw that's being used by the car, which would give over 200 amps at 1500rpm. Pretty impressive from a v belt alternator in my opinion.
Now, this alternator wasn't cheap. Cost close to $2k to get here. I have been in contact with the distributor who is letting the manufacturer know what the difference is for the GU to the GQ, so they are going to modify the casing, bottom bracket and Pulley.
If you wish to look into this, contact below;
Workplace Safety
Compliance Pty Ltd
Trading as : M2K
Alternators Australia
Attention: Jim Impey
9 Dwyer Ct
DONVALE VIC 3111
AUSTRALIA
This is from battery app. Engine is approx. 1500 rpm. I only run a 200amp DCS Lithium for everything, so my alternator feeds direct to my battery (No dual battery setup)
Alternator top bracket modified 10mm higher than GQ to fit standard GU bracket
Lower bracket on back of alternator modified 10mm lower to suit GU. Top bracket is modified.
Hope this helps anyone looking for a high output alternator for our trucks.
Workplace Safety
Compliance Pty Ltd
Trading as : M2K
9 Dwyer Ct
DONVALE VIC 3111
AUSTRALIA
