21 - 40 of 380 Posts
I've been back thru the 2001 Patrol bin and looked at all the maps again, all the 2d and 3d maps are identified with all the axis values I know. There are probably quite a few single value limiters but without a Damos ( programmers instruction manual ) file, finding those are near impossible. If you drag the RAR file into the free winols demo version it will accept the bin file but it wont recognise the definition file as it was created in an older version of winols and they aren't compatible. If you have the 2.24 version the bin will load with all the maps identified and the axis populated, from there we can work on what needs changing.
https://www.dropbox.com/s/d1i20l0t73dg2uf/2001 gu patrol ori.zip?dl=0
This is from a 2001 model and as we have found with Navaras the programming has changed with later models, so while all the maps should be the same in later years, they may have different values in some, so it would be best to use this as a guide and then use your own original file if anyone gets to the stage where they do a remap.
I checked the ols you posted, Navowner and have to say - Good job. I already did this in the past, but due hdd failure i lost it. I mean mappack with all maps in the bin.
One thing can be confusing for ones who look on it first time. You have temperature conversion factor applied on all 64606 axis (RPM).
I have one question to Navowner. You named map at 39EEE as MAF voltage. Are you sure with factors you used?
Here is my ori and mappack from 2000 GU manual. I suppose, one of the first with ZD30. My ECU number is 407917-011.
https://www.dropbox.com/s/l4r88buz2w8q2s5/Patrol ori and maps.zip?dl=0
From my experience and bins i collected, the end number (011, 015 etc.) is software revision. Hardware is the same at least to 02-03 years. So you can flash 011 soft to 015 ecu and have 011 ecu.
It would be nice to have collection to compare. There are lots of bins floating on the internet, but the ones with ecu number are rare.
My friend has 015 ecu in his 01 GU auto. I'll upload his ori later (he has ori chips at home).
Maps in my mappack with flags are the ones i changed to tune my car.
What confuses me in this ecu is that according to service manual the maf is used to calculate fueling under normal conditions. I have not found any map with air in mg/stroke or kg/h. Everything is based on boost pressure. It must be conversion map somewhere in the bin.
Boost pressure sensor is linearised up to 2533hpa absolute (4.5 volt signal - 1533hpa of boost = 22.2 psi) in the map at 39E22. It can read further to 5V, then it cause limp. My hand pump with gauge is not able to make more pressure than 22 psi so dont know what pressure it is exactly.
The map which confuses me is at 3CEA0. I named it as "Boost Correction" Z values are in percent. It is not "allowable overboost" because the higher numbers you set, the earlier limp comes. Once I set it experimentally to 150% and it did not allow boost more than 0.7 bar. When you divide max boost value on X axis (2560) by 1.5, result is 1706 minus atmo pressure is 706 = 0.7 bar i read on the boost gauge. It was smokey and low on power.
These days i have it set to 100% (ori is between 105% and 120% on positivie boost levels and usable rpms). It helps from limping.
Remember - I still use factory boost control solenoid.
Writing in English is hard for me. Maybe someone got interested and even look into the bins. More later.
Jan
Hi Jan, Good to see some interest in this. When I searched 64606 I didn't get it as an axis, which maps are you looking at with temp as rpm?
With 39EEE I couldn't find a data sheet for the MAF sensor, so I used a factor for Kg/h that I found for another bosch sensor, so yes it will be incorrect.
Yes there does seem to be lots of boost maps for a car that uses a MAF, reading on ecuconnections it is common for cars to run MAP and MAF and they can switch between the two. There could be a map that converts airflow to boost pressure, something else to research. The Navara manual says that the engine doesn't use the MAP for normal operation so that pretty much only leaves the TPS and RPM which can't be right either.
That's good info on map 3CEA0, lots of the names i've given maps are just guess's as i'm new to all this and am learning from the start, i'm not a mechanic or tuner, just someone who likes to tinker.
I found out few things today. My friend came to me with his 2001 GU auto. His car was already tuned by reputable company with 193hp on flywheel, dyno checked (i doubt it).
The only mod on his car is blocked EGR. Boost controlled by factory boost solenoid, no additional gauges.
I suggested him to install boost and pyro gauge.
He bought boost gauge now, so we installed it first. We made test drive, there were strong boost drops under load and max boost was 13 psi.
Then i read his ori and mod chips and found out, that tuner made few mistakes.
I made my own mod and we both were surprised how his car drives now. It was as night and day. Boost was exactly where i requested it (max. 21 psi). No boost drops under load. Heaps of torque. When we recalled peak boost on his electronic gauge, it was 1 psi only over max requested. No visible smoke. When he install pyro gauge, we check exhaust temps and adjust fuelling to the final value.
I am happy with this result, but disappointed from my own car. It is obvious that i have turbo related problem, because my boost is really unstable with raised fueling. Strong overboosts to 26 psi.
Here is ori soft for 2001 GU with auto trans, ECU number 407917-015
https://www.dropbox.com/s/li8yospiwueznh8/407917-015 Patrol ori.zip?dl=0
Lots of differences in the program area to manual soft. In the calibration area biggest differences are in Start of injection map, VNT precontrol maps and drivers wish map.
I also found one interesting map. It is used for afterglow duration control. I measured afterglow duration on cold engine (8 celsius), it was exactly 5 minutes (300 sec.)
When Navowner posted his full defined ols, I checked it and found map that controls it.
I changed it as you can see on the pictures, flashed to the ecu and measured again - It works.
My glow plugs will be happy :)
When we discussed the MAF, Navowner wrote that wasnt able to find datasheet for it. I think i found some info. It is standart Bosch HFM5 type (i know bosch is not original manufacturer, but those are well documented. Bosch also makes MAF for Nissans - pn 02800218152, HFM 5-4.7 type). Bosch dont sell the only sensor as Nissan does, only with housing.
According to Bosch datasheet it should be type 3 (71/80mm housing ID/OD) 640 kg/h. Unfortunately in the catalogue is PN 02800218152 listed as 5-4.7, not 5-6.4.
I didnt find datasheet for HFM5 470 kg/h with housing ID 71mm, only this one. There is curve for 470kg/h type with different housing. Maybe useless.
https://www.dropbox.com/s/a31rujbavc7yw86/Bosch HFM 5 sensors_airmass.pdf?dl=0
Maybe one day we will be able to find the conversion used inside this soft between boost presure and amount of air and precisely calculate A/F ratio. Not just guess or rely on visibility of smoke or raised exhaust temps.
More good info Jan, I guess that answers the question of whether the DI can be mapped.
If the MAF is 640kg/hr just change the x axis factor to 0.05738 (from 0.03362). To get that number divide 640 into 11152, which is the highest number on the x axis.
Discussion starter · #28 ·
You lost me at x, when you get it sorted and stop speaking a foreign language let us know the outcome................................:confused:
Now, as a very simple question, there appears to be at least 3 generations in the ZD30DI ECU (maybe someone can clarify that point) mine is October 2000 build so I'll say first generation, to which generation(s) do you refer?
I do not understand this sentence. If it is related to my poor English, then i'm sorry.
If it is related to the subject "Reflashing possibility of DI Ecu", then i am bit dissapointed of your attitude to the subject. I supposed it is about how to do it yourself and not "when you finish, let me know". I know it is not for everybody, but tuning factory ecu is done this way.
I am not professional tuner, just enthusiast who loves challenges. I dont want to sell you final product.
I started with this maybe 2 years ago. Got stucked several times to the point where i wanted to give it up. There was not any public info about this ECU. Seemed no one interested in. I wanted to start public discussion about it as it needs more brains working together.
The task "Reflashing DI ECU" has 2 parts.
First is how to do it physically. It is the easy part. Just change 2 not electricaly erasable chips to another ones. Read old, write modified soft to new. Thats all.
Second part is how to modify the software and understand this ecu. Someone told you, that only fueling can be adjusted. Thats not true. You can change everything, what this ecu does. Boost, injection timing, fueling, glowing, alter curves for sensors like MAF, MAP, temp sensors. Anything what you are able to recognize in the software.
I suppose limits of safe mod controlled by ecu without fooling any sensor, is 22psi of boost and aprox. 80mg of fuel per stroke. Should be 200-220 hp on flywheel with IC upgrade.
One day, when i finish with my car i will go to dyno and measure it. I use my car just for holidays and meetings, so i am not in hurry.
Simple answer is: I talk about first genertion, 00-03 years. The ecu files in this topic are from 2000-2001 cars. 04 should be a facelift. I dont know how you call it - GU4? I think those ones have EDC16 obd flashable ecu. Same engine , but completely different ecu. 07 CRD is again completely different.
It's not your English mate. Your English is pretty good.
"Lost me at x" is a bit of Aussie slang. Meaning that he couldn't follow what you are doing because he is not one of us tech heads and did not understand. He does understand a fair bit for a "old" mechanical engineer but his generation did not have electronics and computers so a lot of it is rocket science.
Keep up the good work. Im getting very interested in your results.
Sent from my work phone because I don't have the time to get my laptop out. its a Samsung cause im cooler than you
As for ecu variants I've being using ecu's marked as "A9" in my Navara and haven't had any problems with using ecu's from other years as long a they are A9, however, another Nav forum member bought some ecu's that had "DFP" instead of "A9" on them, and when he wrote my map to them the car would start and run for a minute or two then stop, so there are differences and it is best to use ecu's with the same numbers on them.
I compared the two files and there were about 4 maps that had minor changes but a lot of random single values were different as well. I remapped his DFP file, wrote it on some chips and put them in my A9 ecu and didn't have any problems on a half hour drive so i'm not real sure what the problem was but think it might be hardware related.
I've probably written 300 different maps to my ecu so well understand the procedure, it just becomes a mater of making changes and going for a drive to see how it affects things. The main maps you need to change are obvious once you have done the research, it's just finding the single values limiters and understanding the minor maps that takes time.
lots and lots of learning to do.
I'm impressed with what I've seen so far. :)
Rumpig's advice has been invaluable.
Turning EGR off is a lot better than blocking it because you don't get the associated fuel reduction. Simple too.
There is a lot to WinOLS. Slowly learning it. Did I mention that us IT guys hate having to RTFM. ;)
Drivers Wish will be a fun map.
Discussion starter · #35 ·
Have been away on a long road trip so just caught up with this. Absolutely no reflection on your English whatsoever, I'm just not that sort of person.
In 1986 I did a PLC1 course just to give me an idea of what was and what was not possible for the Electricians that worked for me on packaging line installation projects, so I understand EPROM's as a matter of fact I build JayCar Voltage modifiers for people, some of whom are from Europe and speak to me through Google Translate, that is a challenge sometimes.......
It was in fact me who started this thread as I'm very interested in the possibilities due to the fact I have a project in mind for this year that would be helped greatly if we could sort something out.
Thanks for the answer, I knew there were at least 3 ECU upgrades as the 3L developed. I look forwrd to more information as we go but, this is a level above me so there is no way I could do the ECU re flash job.
Hi Honzak,
Thanks for all your helpful information.
I have a 2004 GU4 auto with ecu partnumber 407917-170 0
How would I tell if this ecu is EDC16 obd flashable? Do I need to take the cover off and have a look if it is different to your photos?
It has been quite interesting looking at the winols maps. You and navowner has done some great work.
Thanks
Being that only wagons have immobilizers it might be possible to get a secondhand ute ecu, socket that then just unplug the immobilizer at the ignition barrel. If the sockets failed you could just put your original ecu back in and plug the immobilizer back in. Did something similar on my motorbike.
I am not sure about GU4 ecus, but you can open it and compare with picture in this thread. I posted zip file in one of my post with picture of the ecu board.
I was told, that GU4 should be obd flashable, but i am not sure.
To the immo problem. Immo information is stored in another Eeprom (24C02 SOIC8 type) on the board. I have file for immo off for this chip, but not confirmed it is working solution.
If someone read this eprom from ecu without immo it should work also in the Patrol ECU.
Navaras here in Europe doesnt have ZD30 and have NATS, so I dont have access to it.
Another way is taht you can of course write immo data from your own ecu to the new (spare) and dont make it immo off.
I'm not 100% sure but I believe all DI's need the chips replaced and CRD's can be flashed thru the OBD2 plug. I think 2006 was the year diesels had to become OBD2 compliant.
You have to desolder both eproms and socket the board first. Then copy the rom to your pc and mod it.
The eproms on a Di are write once. This isn't a issue as you can get rewritable ones for about $4 each. You need a odd and a even chip so that is $8 :)
I need a lesson in injection timing now. Lots more learning....
